- 18 May 2010
Yeah bit of an odd one.
My desk cant be moved, it is fixed. There is a 20mm gap running along the back for cable management.
Is there anyway I can fit a monitor arm to it without cutting into it? Maybe the C clamp can be pushed in at an angle or something? I think what I'm asking is if anyone can recommend a monitor arm where the clamp can fit through a 20mm gap?
Long shot but you never know
Thanks
Thanks
