Breathable Business Shirts
Yeah, forget Primark for shirts and go to one of the "london" brands (TM Lewin, CT etc), or probably somewhere like M&S. TM regularly do sales with 4 shirts for £100 so not that expensive either.
I never pull the shirt up over my mouth so i dont see a problem with them being breathable? lol
The shirt isn't the problem, it's the effect. The Lynx Effect. You'll be fighting off the ladies with a little help from Lynx Body Spray. Meterosexual Magazine's No1 odour eroder 2016.
Just buy 100% cotton ones? Should say on the packaging.
This isn't necessarily enough, I think the weave is more important, the finer the weave the less breathable the cotton. I find TM Lewin herringbone shirts the best and poplin the worst. I can't wear the poly/cotton mixes or even 100% cotton non-iron as I find them insanely itchy!
Hi Guys
Does anyone else find a lot of the mens shirts available today from places like Debenhams and M&S are not breathable and you end up feeling very humid and uncomfortable in them? I don't know what is causing this, because 10 years ago I never had this problem, and even though I bought new shirts, I end up wearing my old ones, because they are the only ones I find comfortable. Maybe it is because they have moved to cheaper manufacturing, or favour tighter weaves, or are treating the shirts in some way? Anyway, this is a problem for me, and I end up going to TK Maxx and buying random brands in the hope that some will be breathable and comfortable. However, this is a bit hit and miss so can end up being expensive.
Has anyone else had this problem and where did you find some good breathable shirts?
Thanks
