This stands out, looks like your running a VPN, nordvpn-service.exe, try closing or uninstalling nordvpn.
Also I'd completely uninstall the AV, if windows is fully updated you shouldn't really need it unless your downloading dodgy files. You can always reinstall it.
It will take a while to go through the rest but a couple other ones look a bit suspect.
Ah, I didn't quite think about that due to the VPN not actively being open/running a VPN, although I'll try uninstalling both that and the antivirus simultaneously to troubleshoot if it's one or both of those and I'll run the speed test and come back with another post in a few moments afterwards with the results, although I determined that the antivirus alone doesn't throttle the speed due to having tried uninstalling that previously to test. I'll be back with another reply in a few moments anyhow
 I think the fact of keeping/having the antivirus has just turned into a habit from even back in the Windows XP days and all as a precautious security measure though
