low budget air cooler for ryzen 3600
Probably get shot down for this, but my TEMPS were hitting 90c+ - i wanted RGB and a decent looking one, not one that towers over everything.
I went with the AMD Prism and its dropped my temps by 10c+ - cinebench was running at 91c by then end, its now at 71 - 73c
Decent drop in heat for £20 ordered from OCUK
I appreciate there are probably better ones, but this was my experience with a £20 AMD cooler.
Seen some videos on the following cooler if you want RGB particularly seems good value.
Deepcool GAMMAXX GT 29.5 CFM CPU Cooler OCUK don't stock it though. It's available for around £35.00
I suggest you watch the review I posted again (or at least actually watch the performance sections once)- the review shows it getting a lot better results than the stock cooler and is comparable to th 212 (I posted after the op said he was considering it) for a vastly cheaper price whilst remaining almost silent.
Sorry, but I'm not buying or suggesting anyone buy no-name products like coolers when for less then a tenner more they can have a known quality cooler.
:rolleyes:
What a joke. That's only because your suggested Matterhorn is B Grade in a sub standard package with a MASSIVELY reduced warranty and possibly missing parts - it's utterly retarded to think you can push the quality argument with a B grade item.
The matterhorn is a mediocre cooler for A LOT more money when bought new. The matterhorn is middling at best and comparable to 212 despite your comments
https://www.overclock3d.net/reviews/cases_cooling/cpu_air_cooler_mega_test/39
The op is looking for a budget, good value cooler and I obliged with a decent cooler for VERY cheap money. I suggested a properly reviewed cooler from a well respected you tuber that I have personal experience with. There is no evidence whatsoever of quality issues and it can be bought in the UK with paypal so stop waffling on like quaity assurance in the cpu cooler market is a massive issue it's becoming childish. If it works on day one and isn't damaged in transit it'll be ok otherwise buyer protection is your friend.
I suggest you let it go - I certainly did not make a paerfectly valid suggestion in this thread to be haunted by butt-hurt comments days later just because an altenative has been suggested you take issue with.
