- 29 Sep 2010
So I've got an old Silverstone case, I've removed the front panel and going to create a custom front panel to house a 360mm rad is the plan.
However, the case isn't that high, it'll fit a normal height gpu, but it is quite limited otherwise, I have 22mm worth of play above the pci slot screws to fit a card in.
Is that possible?!
Thanks
Is that possible?!
Thanks
