Connecting to wireless hotspot
29 Oct 2019
Hi all..
Some advice please .
I'm able to connect to a remote free hotspot running 2.4ghz
I am located 25 m away.
I wish to make use of 2 devices on this network, a laptop and smart phone, wirelessly..
Any ideas about what device is required to make this possible?
Thanks
Dean
20 Oct 2008
Depends...
Why aren't you allowed to have multiple devices connected in the first place? That's an imposed limitation and nothing to do with the technology.
Then, what do you have to do to connect to the AP? Is there a web portal you have to enter credentials into for instance?
OP
29 Oct 2019
Thanks Bremen,
It's just a WiFi network login. With no password.
25m is too far to pick up the signal
Can I install a bridge and then create a WiFi network to my 2 devices ??
17 Jun 2012
It's unpractical unless you stand in the street or get a 10m long power adapter and stick a repeater also out in the street.
OP
29 Oct 2019
Thanks Scott ..
What does the nano station plug into on the router? Is it a USB or antenna connection?
Can any router be used?
Does the router need to operate in a specific mode ?
Many thanks
OP
29 Oct 2019
Thanks Scott .. Amazing.. Cheers..
Shall I search for..
Connecting nano station to wan port on router?
And.. Is it OK to go for an older nano, like M2?
Cheers...
(finally in a good direction)
OP
29 Oct 2019
Hi all..
I see online there are many models of nano station. Ie 2, loco, 5, 9.
And wonder what will be suitable for this application if 25m distance, direct line of sight?
5 Nov 2011
Derbyshire
Hi all..
You can't "decide" which to use. Loco M2 uses 2.4Ghz, M5 uses 5Ghz and the 900 uses 900Mhz spectrum. You will likely need an M2.
OP
29 Oct 2019
Thank you .. Which is the entry level nan , that's the MOST cost effective, and cheapest for me ..
Does the nano 5 only work for 5ghz?
The signal in trying to connect to is a 2.4 ghz one
29 Dec 2002
The 2 and 5 have significance across the range.
