yes it's sneaky but who really ******* cares?
I've been reading up on this, yes it's sneaky but who really ******* cares? I mean we all use Facebook, Instagram, Google services, Microsoft etc etc. They all farm your data and in a much worse way than a few crash reports do.
You can get a Mikrotik switch that isn't too expensive, I've got two to complete my 10 Gbit network.Yeah that's what I had seen, was just curious if there was a way around that or a setting etc.
Would be nice as I could avoid buying a dedicated 10G switch for my current PC and NAS that support it.
Also saw over on Reddit that there was a new Amplifi 802.11ax product on the way.
I'll leave it in mate, it would break the flow of the posts after it..Thanks the-evaluator , can a Mod delete post #3678 ?
Thanks
@WJA96 or anyone else that may know
With the UDM Pro can the two SFP+ ports be used for switching or is one dedicated just to WAN?
Thanks!
No need to delete it I would say, the like to El Reg is a useful read.
No harm done by your post
I hadn't seen the news on it until I saw your post on the topic.
I've been reading up on this, yes it's sneaky but who really ******* cares?.
If you're on a UK ISP, there is almost no reason to upgrade from a USG or USG-Pro because those devices can run IPS/IDS at UK ISP line speeds. The controller feature set is identical. Because it's the same controller.
Not for much longer. Gigabit connections are gonna be a lot more common in the next 6 months.
Those same people likely won't be using Ubiquiti gear though, so they're irrelevant. There'll be a large crossover between people with their own home networking setups and people looking to move to 1Gb as soon as it's available.Availability might improve but the prices being quoted won't bring in huge numbers of users. Most folks I know are still on a 38Mbps download contract because to go to a 76Mbps contract doesn't really get you any extra functionality in terms of streaming and the prices are quite a bit higher. To ask someone paying £30/month for 38Mbps to go to £65 plus for 1Gbps simply won't get you much uptake. It will come down as competition goes up, but it's not going to be commonplace in the UK for a while yet.
I think there may be some confusion. There are two SFP+ ports, one is coupled to the 1Mb RJ45 WAN port so whichever one you use, the other is disabled and that is the primary WAN port. The other is coupled to the 8-port switch so it is a 10Gb uplink that you can connect to a US-48 or US-48-500W/750W or a USW-Pro-24-PoE or USW-Pro-48-PoE or a US-6-XG-PoE or any switch with an SFP+ port.
The 2 SFP+ ports are on different chips in the device.
But! Any port is mappable, so you could make any of the switched ports an additional WAN port. My reading of the spec sheet is it's a weird product aimed at extreme prosumers who want a very fast rackmount router and they want to run their cameras off the system as well.
There are lots of rumours about a true USG-4P (Pro) replacement that doesn't have a built-in controller and doesn't have a HDD slot or a built-in switch.
And fundamentally, if you're on a UK ISP, there is almost no reason to upgrade from a USG or USG-Pro because those devices can run IPS/IDS at UK ISP line speeds. The controller feature set is identical. Because it's the same controller.
