pc crashes while playing games.. screen turns black and wont turn off
7 Nov 2019
hi.. so
i recently build a new pc for myself but now when playing certain games my pc just goeas black.. all the fans and lights turn off and i cannot turn the pc off with the power button.. i have to do this on the mains
it was crashing on world of warcraft untill i turned the graphics down and now its crashing on pubg... my pc should be able to handle each game on ultra ..
specs are
windows 10 pro 64 bit
ax370 gaming k5 motherboard
amd ryzen 7 2700 8 core 3.2g/hz
16 gb corsair vengence 3200
rx vega nitro 64 sapphire
the windows reliability report says hardware crash but doesnt point me to anything inparticular
any help will be appreciated
many thanks
craig
Check event viewer in Windows. Right after a crash, go find the event log under system or power. You should find a gap where the PC was off/crashed. Right after that will be some clues as to the recovery, and if you're really lucky right before the crash will be warnings.
How are your thermals? Is the system overclocked? Is your power supply rated and reliable enough to feed that graphics card?
system reliability most of the time will say
critical events
windows windows was not shut down properly
but will occationally say hardware issue
Description
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
Code: 141
Parameter 1: ffffa60d172d3050
Parameter 2: fffff8043e7d077c
Parameter 3: 0
Parameter 4: 10d0
OS version: 10_0_18362
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.18362.2.0.0.256.48
Locale ID: 1033
thermals are ok.. nothing really gets above 50 Celsius
this is my power supply https://www.overclockers.co.uk/search?sSearch=Zalman+700TX+700W+80+Plus+230V+EU+Power+Supply
im absolutely baffled.. bios are up to date
Have you an overclock on your CPU or GPU ?
If so reduce them and try again at stock.
If not can you try and downclock your GPU and try again.
you can use things like PC part picker to calculate your minimum power requirements. usually a good idea to increase this by 30%
so... turns out my graphics card is a thirsty bitch.. 700w pse is NOT enough lol.. ive underclocked the gpu and this has solved the issue.... thanks for the replys though
Without seeing any tests I can say pretty safely that's no 700W PSU.
Zalman has never been any quality PSU brand with at best average PSUs.
And that's no doubt garbage level PSU with all that 230V only design.
Here's review of same factory's supposedly better model with proper active-PFC functionality:
https://www.hardwareinsights.com/zalman-zm600-lx-power-supply-review/7/
Even if electric performance weren't bad also that construction quality isn't much above garbage with some clear major issues in soldering quality.
That kind soldering issues can actually make things burn from overheating.
Wouldn't do anything stressfull until getting proper quality PSU.
Bitfenix Formula/Seasonic Core Gold would be my starting level recommendation
https://www.overclockers.co.uk/bitfenix-formula-series-650w-80-plus-gold-power-supply-ca-22z-bx.html
https://www.overclockers.co.uk/seasonic-core-gold-gc-650-650w-80-gold-power-supply-ca-070-ss.html
For modular cables Bitfenix Whisper M/SuperFlower Leadex III are cheapest.
Sesonic Focus Gold based Phanteks AMP is best priced from good 10 year warranty models.
https://www.overclockers.co.uk/phanteks-amp-650w-80-plus-gold-modular-power-supply-ca-09q-pt.html
(Corsair RM has second/third tier capacitors giving it minus point)
Quality 650W PSU is enough for Vega, but if you go say overclocking things further 750W PSU is good sizing.
