Caporegime
- 18 Oct 2002
I didn't think there was a 256Gb 7T ?!
Yes but outside UK only, hence the grey part
Ah OK... sounds like a good deal, too risky for me though with my luck
Something I've noticed since moving from Pixel to OnePlus, the battery life on my Samsung smart watch is massively improved. I can only assume the Pixel was constantly communicating. This may have been a rogue app for all I know, but thought it worth a mention.
I assume they’re connected via Bluetooth? Funny you say that as when I sent my 2xl back for rma and moved to an iPhone I found the battery life on my BT headphones improved considerably.
This isn't just a little bit better, we're talking going from lasting 2 days to lasting 5, maybe a week. I'll need to test to be sure.
Another difference I've noticed, is that the connection between the devices rarely gets lost whereas with the Pixel if I left the watch upstairs and the phone was downstairs then the connection would constantly connect and disconnect.
Can't say I've noticed. Although define high? Mine has used 8% battery since full charge, second behind internet browser on 9%. But then I do use WhatsApp quite a bit.https://www.reddit.com/r/Android/comments/dsx1zq/psa_there_seems_to_be_a_huge_battery_drain_issue/
Any of you guys seen a drain by Whatsapp on your Oneplus devices? Looks like its an issue with OP and not other devices.
Just an update in case it helps. As I say I saw no noticeable drain with my WhatsApp although after my previous reply it went up to 11% from 8. Anyway I went into the app options and then battery optimisation and changed it from Intelligent Control to Optimise and since yesterday evening it hasn't even registered 1% usage. Most importantly it still functions 100% and I get all my notifications.https://www.reddit.com/r/Android/comments/dsx1zq/psa_there_seems_to_be_a_huge_battery_drain_issue/
No one can help me, or no one knows?Anyone else have a 7 pro 5g? Know anything about when android 10 is coming for us, there's literally no news.
Also does anyone have black screens when trying to views some streams on the twitch app? It seems to be when it's 1080p and nvidia nvenc based. I can direct you to one that I have problems with if someone can try?
Probably very few 5G phones owners around, maybe check the official OP forums. A video I was watching this morning mentioned 5G phones might not get updated to 10 until early 2020, couldn't tell you if that's accurate.No one can help me, or no one knows?
