New monitor to compliment new PC - £250.00 budget!
You are right to be concerned. 27" is the sweet spot for 1440p. At 32" you may well see pixellation.
I assume it's worth dismissing the idea of a 32" then?
It's always worth making a post in the Customer Support section of the forum and asking about the condition of any B grade item you're interested in, also ask if that's the best price available as they may well lower it, they did after I asked about some equipment awhile back.
Already emailed them about a couple of other items before and was told they can't advise me on why a specific item is B Grade :( I guess no harm in making a post instead.
Would it be a worthwhile purchase if I pulled the trigger on the Samsung? Reviews seems positive, but then again I'm far from having any real knowledge on monitors to know if something is wrong with the spec.
Damn good price on it too.
You've a pretty badass gaming setup now!
Hell yeah, super happy with it all.
Thanks for your help as well with everything, it's very much appreciated.
Feels good to no longer be using a PC that struggled to even hit 30fps on lowest settings on whatever game I tried :p
Not a problem mate, glad you're enjoying the build!
