5700 (non-xt) is about 25-30% faster than the 1660 super
1660 super is £200
if price/performance is to be kept the same...then 5700 should be £250-260
but the cheapest is £300 - and that's with an awful cooler that i wouldn't even recommend my enemies to buy
the cheapest aftermarket cooled 5700 after that is £350...by which time this is within spitting distance of the 5700xt
I am going to throw a spanner in the works and say change the case as well. One of my reasons is that case uses the psu as a exhaust which is a bad idea and will lead to the psu trying to cool itself with already warmed air. This will lead to a higher fan speed and more noise and has the potential to shorten the psu's life. Another reason is that the gpu's being mentioned are going to dump a lot of hot air into the case which a 80mm or 92mm fan isn't going to shift much of so again will be on the psu to shift it. That case could end up as a hot box and lead to thermal throttling. You don't have to spend a fortune to get a decent looking case with very good cooling options and the psu in the bottom where it belongs. The Zalman S2 for example is only £32 and will take 3x 120mm fans in the front, 2x 120mm fans in the roof and another 120mm fan in the rear.
I really don't believe that the hardware recommended would lead to that case becoming a hot box, neither the 3600 or the 1660S generate a lot of heat. Furthermore, they don't use a lot of energy either, they'd run on a 400W PSU just fine let alone the recommended 500-550w units earlier in the thread, so hardly pushing their power supply. I know where you're coming from but in this specific scenario I'd say it's an exaggerated potential problem. With a good intake (which he already has) and the exhaust fan recommended by @tamzzy I simply don't believe there will be any problems whatsoever with the setup the OP intends to use.
I just wanted to follow up on this. I've finally completed the build. I ended up going for the Corsair Vengeance RGB Pro 16gb 3200Mhz just for the disco effect, went for the RM750X PSU and Gigabyte 1660 SUPER OC edition.
