- 1 Dec 2015
been banned for a while so finally getting around to doing this
Enter the sTRX4 socket and RTX40 Chipset !
remember 2nd gen Thread ripper cant be used on 3rd Gen Motherboards and vise versa
Gigabytes Flagship RTX40 AORUS XTREME !
https://www.gigabyte.com/uk/Motherboard/TRX40-AORUS-XTREME-rev-10#kf
16 phases via 16 channel PWM (Same as featured on X570 Master and Xtreme) unleashing 1120amps across the vCore and 210amps (3x70a) across the SoC.
Board is also 10 layer PCB
Finned heatsink on the VRM banks with small fan ( this time there is a vented area at the back of the IO shield!) The IO cover is also Aluminum and directly connected to the Heatsink for extra surface area and weight !!!!
Boards Preview
Next in Line RTX40 AORUS MASTER
https://www.gigabyte.com/uk/Motherboard/TRX40-AORUS-MASTER-rev-10#kf
Features the exact same VRM set up as the Xtreme ( 16x 70a vCore + 3x 70a SoC) !!! but heatsink design is a set down in design and comes with backplate
Personally makes more sense over the Xtreme, specially if it means you get the same VRM set up but can spend the extra £200+ on pushing more cores for purchase
Nice to see Master also has vented IO shield !
And then we arrive at the Entry model RTX40 AORUS Pro Wifi
https://www.gigabyte.com/uk/Motherboard/TRX40-AORUS-PRO-WIFI-rev-10#kf
Key difference between its and its bigger brothers, ATX design and not EATX and also 12+2 phase design rather then 16+3.
It still retains the 16 pwm controller but only using 14 channels with 2 of those for SoC
12+70a = 840amps across the vCore and 2+70a = 140amps for the SoC
Just to hit home, the 2nd Gen Aorus Xtreme was a 10+3 Phase design equaling 500amps across the vCore and 150amps across the SoC. So the Entry TRX Aorus smashes the older designs along with added PCIe 4.0 support
https://www.gigabyte.com/uk/Motherboard/X399-AORUS-XTREME-rev-10#kf
downside and kicker... Boards will cost a BOMB! X570 Xtreme lists for £700 and that has half the PCIe 4.0 lanes, which is the main factor in costing, then the huge socket design!
Boards Preview
