- 7 Nov 2017
check your ram settings are actually ok also make sure you are on the latest driver. I had the same issue with my 5700xt (daisy chain, 650w PSU and 3900x) no issues now.
Will do - definitely on the latest drivers, but what would need changing RAM wise?
Just awaiting a response from seasonics European partner for a cable. Fun fun!
Focus gold is a single rail PSUAlways use separate rails for a GPU tbh.
As above, it could be ram. Are you using 2 sticks or 4 and have XMP enabled?
Says on the box that there should have been two cables in there, surely they can't lie about that. You're right though, it is single rail - so you're saying an extra cable won't help?Just FYI, the 550w PSU only comes with ONE pci-e power cable. It's the 650w and above that comes with two.
It's another sneaky way that PSU manufacturers use to ensure that their PSUs are upsold.
2x8gb. I believe XMP is still enabled currently. I was having issues a few months back with XMP enabled as that was causing blue screens also. I'll check later.
Well I'm lost for solutions then Don't know where to go from here!
pretty sure you've read it wrong. it should say pcie 6/8 pin x2 which equals one cableSays on the box that there should have been two cables in there, surely they can't lie about that.
correctYou're right though, it is single rail - so you're saying an extra cable won't help?
How do I do that without completely wiping everything? Is that even possible? If I have to do a complete reinstall then so be it!have you tried a fresh windows reinstall?
i highly doubt its a psu fault tbh.
Backup what you need and start from there.
Ah okay, I'll have to find my external harddrive somewhere!
Sorry, what do you mean about the drivers? Won't I just install them after the wipe?Don't forget the latest chipset and graphic drivers and other drivers you need before wiping. Steam games use cloud saves mostly and the likes.
