Ongoing problems with 5700XT
13 Apr 2017
Hey all,
As the title suggests, I'm having some rather annoying issues with my 5700XT that I've had for around a month and a half.
It's causing some really annoying stability problems, and the number of BSODs has gone up quite a lot(1 every other day? Rarely the same error code)
The issues are very prevalent when playing R6 Siege, when minimizing the game makes both on my monitors go black, even though the pc is running fine in the background. I have to turn my monitors off and on to make them pick the signal back up.
I've got a 550W Seasonic Focus gold PSU, which I was told, although it doesn't meet the minimum reqs, should be fine to run the GPU. I've tried underclocking/undervolting to a variety of different settings that have been suggested to me, but all of them eventually hit a bsod when gaming.
Is it time for an upgraded PSU? I've used DDU on safe mod and still have the issues :(
Any guidance will be helpful :)
Cheers
Current Specs (Not including PSU mentioend above):
R7 2700
X470 Ultra Gaming
8pack TeamGroup 3200mhz 16gb
This is after all the things you've recommended in my other threat about 58700xt vs 2060 Super, Panos.
Not sure what else to do now! :(
Are you using two separate cables to power the GPU or are you Daisy chaining. If you doing the latter that might be your issue.
It's just the one cable coming out of my PSU, splitting into a 4pin and a 6pin (or whatever it is, not at my PC right no to be able to check haha)
Then you are daisy-chaining. Try two separate cables should improve the power delivery to the card.
Okay, so it turns out I'll need to buy one. Think I need a 6+2 each end? Then 8 can go in the PSU and 6 in GPU. Does that sound correct?
PSU says it comes with two 8/4 pcie cables but can't find the other one anywhere..
Finally going a BeQuiet one on the big rainforest in South America. Presume that'll work on Seasonic. Hopefully this solves my stability issues!
So I was advised that using beQuiet cables on Seasonic wasn't a good idea, so I've cancelled that order. Only problem is, I now have no idea where to get Seasonic cables from!
check your ram settings are actually ok also make sure you are on the latest driver. I had the same issue with my 5700xt (daisy chain, 650w PSU and 3900x) no issues now.
Will do - definitely on the latest drivers, but what would need changing RAM wise?
Just awaiting a response from seasonics European partner for a cable. Fun fun!
Always use separate rails for a GPU tbh.
As above, it could be ram. Are you using 2 sticks or 4 and have XMP enabled?
2x8gb. I believe XMP is still enabled currently. I was having issues a few months back with XMP enabled as that was causing blue screens also. I'll check later.
Just FYI, the 550w PSU only comes with ONE pci-e power cable. It's the 650w and above that comes with two.
It's another sneaky way that PSU manufacturers use to ensure that their PSUs are upsold.
Says on the box that there should have been two cables in there, surely they can't lie about that. You're right though, it is single rail - so you're saying an extra cable won't help?
Well I'm lost for solutions then :D Don't know where to go from here!
Edit: wasn't XMP enabled. I've now put that back on, just so I know, what effect is that going to have?
No new to PC and it's my first build but I was getting BSOD at the start with few teething problems but seen on Reddit if I change my PCI to Gen3 bios it should work with my Mobo then should say in wattman system - hardware Current bus settings 3.0 x16
Oh right I see! What's your mobo?
