Best solution to my FPS bottleneck...
15 Oct 2019
Uk
OP
11 Aug 2015
With it disabled the score improves a little, but the RAM has reverted back to the 1066hz (or there abouts)...
https://gyazo.com/ccb2af7e3e8005006f6b6092f5b5c3c7
FPS hasn't changed either, but my display seems much laggier than before. Previously I had a smooth image, now it's stuttering. :(
15 Oct 2019
Uk
Could try a hard reset of the bios either with the jumper if the board has it or by removing the cmos battery.
Have you updated the chipset driver if not try this first.
27 Mar 2009
If I'm reading that right in your last run your at 1066 and at the start of those thread your score was 769. I would say that's a good improvement.
If your game FPS hasn't improved though I don't know where the bottleneck is.
All you can do now is install MSI afterburner and log everything over a duration. That way you can see FPS and the clock speed of your GPU and CPU cores over a length of time.
26 Aug 2013
Run a graphics test, Ash. Unigine Valley or Heaven (extreme preset). You should see GPU usage hit 100% in that. Grab the score.
As for RAM try 2666MHz and see if you get better results than with 2133MHz. Maybe the RAM, or the motherboard, or the CPU's IMC, doesn't like 3000MHz.
OP
11 Aug 2015
This was the first score after updating the BIOS drivers, bud.
How do I change it to 2666mhz? Manually in the BIOS?
26 Aug 2013
Your Heaven run was on custom settings so I wasn't able to compare that graphics score with others using the Extreme Preset.
And you need to figure out a way to set a different speed for the RAM. Can't help you there.
CPU seemed fine.
