- 15 Feb 2013
- Edinburgh
Here's some photos of the living room, where I'd want the TV space. I'm considering pulling the whole fire bit out when I get the boiler changed and possibly having that as the TV space
The cupboard? There's a hot water tank, which will be removed when I change boiler
I would fill the door in on the front....create a small door on the side and house all av gear in the cupboard out of sight..
Get rid of the fireplace...mount the TV and put the in wall speakers in place...
easy install....I had to get my mate with a diamond saw to come and cut holes in breeze block for my in walls speakers !
Sounds a reasonable use of the space
I had considered tucking everything in the cupboard in bedroom 3? Is that just going to cause me problems running cables /controlling things?
So, if I go with fireplace goes, TV there, cabinet for the equipment etc.
As there is a window to the right, what would the best plan be for the rest of the speakers? Would in ceiling ones be good? Or is that just a fad when going for surround sound?
Well I suppose I need to know the options
Atmos the dolby solution I assume?
