Best rtx card just now?
14 Jul 2009
Hi so in the next coming mouths i should have some cash to upgrade my gpu but before i do i want to ask whats the best rtx card that I should pick up? This card will be for 1080p gaming and video converting. So what the best rtx just now?
None atm given they are over 1y old and in just 3 months outclassed and outdated.
:eek: :D
The 2070 Super is the best buy at present.
What are the full specs (including psu make and model) of your rig, and what is your budget?
Technically the "best" RTX card at the moment is the Titan RTX, but I doubt you want to put down £2300 + on a graphics card.
AMD Ryzen 5 3600 Processor (6C/12T, 35MB Cache, 4.2 GHz Max Boost)
MSI B450 TOMAHAWK MAX Motherboard
RADEON R9 280X GAMING 3G
Corsair CMK8GX4M1D3000C16 Vengeance LPX 8 GB X2
Intel 660p M.2 2280 512GB PCI Express 3.0 NVMe Internal Solid State Drive Rev:4.00 (OS DRIVE) (2019/08/09 sticker date)
Corsair 550 Power Supply
corsair stormtrooper case
i was thinking of buy a psu also with gpu.
What Corsair PSU is it? There's a lot of different models made by different OEM's under the Corsair brand.
It's a pretty solid PC, a 2070 or 2070S would fit the bill nicely assuming they're within budget.
If the PSU you're using is decent you can just keep it, 550w is plenty for that system.
I got the power supply from you on 23/04/2014 i might buy a new one but not sure i can go up £200-400. Corsair RM Series RM 550 80+ Gold Power Supply CP-9020053-UK BUT The fan has never been turned on or even spins in the time i have had it.
1650 Super/1660 Super then. Both are solid picks, up to you what you're comfortable spending.
There are not RTX Cards......
Thought you said you want RTX card not just a card.
Should still be fine and well within warranty. Corsair is 10yrs I believe.
Just grab a 2060 super. Won’t have any issue at 1080p 60hz.
If budget is an issue then 1660 super.
As mentioned above by @Panos the 1660 isn't an RTX card, although at this point I'm a little confused as to what exactly the OP wants.
The PSU should be fine, unless there's specific issues being had there's no need to replace it.
For a £400 RTX card the following would be worth considering:
My basket at Overclockers UK:
Total: £709.98 (includes shipping: £0.00)​
If the OP just needs a card that's good for 1080p gaming the following would also be worth considering:
Total: £349.99 (includes shipping: £0.00)​
@OP: Do you actually understand what is meant by RTX? It's the moniker given to Nvidia cards that support real time ray tracing, I think it's important to establish whether or not that is what you specifically need/want or if you're just looking for a GPU upgrade in general.
Actually also can get a good 5700 non XT for less than 300
I never realised there was a super version of the 2060!
What's the difference between a 2060 super and a 2070 as they seem to be priced very closely?
may i ask is the
GEFORCE RTX 2070 MINI 8192MB GDDR6 PCI-EXPRESS GRAPHICS CARD
any good i love the mimi idea but in terms of performance is the same as its bigger brother?
may i ask is the
For £375 you can buy an AIB 5700XT which is faster and save some money also.
This has actually, and quite literally just been reduced since I last checked:
Total: £299.99 (includes shipping: £0.00)
Not a bad price, prior to that the cheapest OCUK 5700 was a blower/stock card for £320.
Not a massive difference, technically the 2070 is a little faster, but a higher end 2060S will probably match or beat a lower end 2070.
may i ask is the
These cards don't use a lot of power and don't generate a ton of heat, so a smaller form factor isn't that big of an impact on them as many would think. The MINI will perform just fine, and if it's the Zotac version you're looking at it has the added benefit of a 5 year warranty compared to the 2-3 of most brands.
They both use the same chip, but the 2060 Super has a few more cores disabled. This boils down to about 4% performance advantage for the 2070. All in all, you can pretty much think of them as the same thing.
