Hi so in the next coming mouths i should have some cash to upgrade my gpu but before i do i want to ask whats the best rtx card that I should pick up? This card will be for 1080p gaming and video converting. So what the best rtx just now?
I got the power supply from you on 23/04/2014 i might buy a new one but not sure i can go up £200-400. Corsair RM Series RM 550 80+ Gold Power Supply CP-9020053-UK BUT The fan has never been turned on or even spins in the time i have had it.
1650 Super/1660 Super then. Both are solid picks, up to you what you're comfortable spending.
If budget is an issue then 1660 super.
As mentioned above by @Panos the 1660 isn't an RTX card, although at this point I'm a little confused as to what exactly the OP wants.
The PSU should be fine, unless there's specific issues being had there's no need to replace it.
For a £400 RTX card the following would be worth considering:
My basket at Overclockers UK:
- 1 x Palit GeForce RTX 2070 Dual 8192MB GDDR6 PCI-Express Graphics Card= £359.99
- 1 x Gigabyte GeForce RTX 2060 SUPER WindForce OC 8192MB GDDR6 PCI-Express Graphics Card= £349.99
If the OP just needs a card that's good for 1080p gaming the following would also be worth considering:
@OP: Do you actually understand what is meant by RTX? It's the moniker given to Nvidia cards that support real time ray tracing, I think it's important to establish whether or not that is what you specifically need/want or if you're just looking for a GPU upgrade in general.
I never realised there was a super version of the 2060!
What's the difference between a 2060 super and a 2070 as they seem to be priced very closely?
may i ask is the
GEFORCE RTX 2070 MINI 8192MB GDDR6 PCI-EXPRESS GRAPHICS CARD
any good i love the mimi idea but in terms of performance is the same as its bigger brother?
Actually also can get a good 5700 non XT for less than 300
may i ask is the
