 - 12 Dec 2019
Took delivery of my GPU from overclockers today.
So I didn't realise the card would be restricted on windows 7. Kept Geforce 970 card in and went through the update to Win 10. Doing OK then about half way through it stopped. Reserved partition failure. Downloaded partition wizard. Extended from C drive another 398 MB leaving just under 500 MB free.
Tried again. Got a Microsoft Office 2010 (can't remember exactly what program was) warning saying need to uninstall program. It wouldn't on the remove programs tab.Spent two hours finding a process to remove it. Managed to achieve that proud of myself (not completely computer literate). Go back to upgrading to windows 10.
Everything working fine. Installation successful. First boot up. Goes through the Win 10 logo then straight to wallpaper (lake, mountains and rucksack plus time/date) Expect my icons and taskbar to pop up. Nothing. No mouse cursor. The only icon is a globe in bottom right corner with what looks like a no entry circle in bottom right of the image. (I suspect this is key info). Ah just looked it up. It's no internet connection.
I think maybe it's the old GPU. Take it out. Try and boot on just the integrated graphics. Same result yet I'm seeing HDMI flash up briefly in top right corner.
All the while the time on the wallpaper is clicking forward so it's not strictly frozen just not booting through.
Put new GPU in. Realise I don't have an HDMI cable.My old system used to run on a DP cable into back of tower display and DVI-D in cable from GPU back into display. Same result. Ordered HDMI cable will arrive tomorrow. Took DP cable out of tower and put it into new graphics card. Same result again.
The only thing I can get into is the BIOS as I boot up.
Anyone any ideas??? Will this HDMI cable solve it. Is this connection issue stopping boot up?
Do I order a Windows 10 bootable USB flash drive?
