Upgrade from an i7 920???
5 Jan 2011
Ireland
Guys i am looking to upgrade from a i7 920,I have a 4 gig rx 580 gpu,My question what do you guys think of these parts and what would you change if any
Gigabyte A320M-S2
Patriot Memory VIPER 4 Series 3000MHz (PC4 24000) 8GB Dual Channel DDR4 Kit
AMD Ryzen 5 2600 Processor with Wraith Stealth Cooler
Looking to spend roughly 250 euro,Also i have a VAT number
Would it be much faster than the i7 920 mate
I was running an x5670 @ 4.5ghz it was very solid, scored over 1000 points in cinebench r15
X5650 is 6 cores So you're gaining 2 cores 4 threads and they overclock very well and run cooler than the 4 core i7s at similar clocks.
Careful with that board, I'm sure I had the same and that particular model wont overclock a xeon, i had the 920 up to 3.8 though
Vcore @1.3-1.35 should be good for 4-4.2
Qpi/vtt 1.25-1.35 depends on how far you push the ram, not a good idea to go over 1.35
Bclk 200 is nice
Cpu ratio 20 for 4ghz with 200 bclk, disable turbo for stability
Qpi link speed, lowest but not slow mode if you have that option
Set uncore to 1.5 - 2x ram speed
Patience...
Google x5650 overclocking guide and there is a lot of good info on the net.
Good luck have fun
God i remember when that hex core xeon was a new top end cpu, people who had them were gods lol. Everyone was salivating and worried at the same time about that new 32nm process :D
