LG B9 + Windows 10 via HDMI - Can't log into windows
12 Nov 2009
London
Happy holidays everyone,
Finally decided to up my TV game to 4K and the B9 had all the right specs at the price point I was aiming at so I treated myself to this fine upgrade.
Initial setup went fine, got up and running, until I booted up my pc to setup the B9 as a third screen, get to the win 10 login screen, enter my password, get the loading dots, windows begins to login.... Then dumps me back at the login screen. The PC doesn't crash, I can enter my pw again, but it just does the same thing.
\- I've tried different HDMI ports on TV and GPU
\- Setup the HDMI device connection to PC and selected the corresponding HDMI input
\- Reinstalled GPU drivers
All to no avail. If I disconnect the TV, I can login to windows just fine. If I login to windows then connect the TV, it registers for a second, my screens all flash (like when you change res/refresh rate) then I get dumped back to windows login screen.
Any ideas?
Interesting issue, personally I'd try reinstalling windows with only the TV connected
Also you say you reinstalled the video card driver but you probably have the same version try an older version
Thanks for all the replies, I think I narrowed it down to the hdmi cable, the display works just fine at anything under 4k (even @60hz it borks). So I've ordered a fresh 2.1 cable, and will try again.
