Ok so, I am running:
3950x on a Crosshair Hero VII x470
Trident Neo 3600 18-22-22-42 64gb (4x16gb)
XMP is... just terrible. Boots to blue screen. No bueno.
DRAM Calculator is... also pretty terrible. The timings seem really screwy, I suspect it's not really optimised for 4 sticks like this.
I can get it into Windows and running RamTest1.1 fairly consistently, to the point where it's -almost- stable. As in, I've done this many times before on other boards and with other components, and unstable ram will throw up 20 or 30 errors fairly consistently. At the moment I'm getting 1 error for every 200% ish.
But I can't seem to figure out how I can fix it, as I'm already on some pretty loose timings (which I expected, I already knew that the chip wouldn't run this much ram at max-specs).
Currently I'm on 3600mhz, 22-22-22-48-62-630 and am on 2T command rate. Running at 1.5v dram (fine for Neo) and 1.2v soc (I thought the soc voltage was helping, as I got a 500% with zero errors earlier, but I just got a single error in another test so...maybe not).
Appreciate any help with this, as I've exhausted my (limited) knowledge of ram.
