I like the CCS vertical entry ones. Two or four RJ45’s in a single-gang sized faceplate. You can use a back box if you want, but they’re designed to screw straight onto the wall. The cables go in from below so there’s nothing sticking out to catch the vacuum cleaner on.
if the Ethernet was routed around the outside of the house, would he drill through and put the cable straight through the wall into the back of that box? So in theory you should only see the box on the wall and the cable plugged into it (that was patched into my switch)?
And don’t run just one cable. Run at least two. Four would be best. You’re only paying pennies per meter for cable and the 4 port box is £3 more than the 2-port box. The expensive thing is having the guy on site. It takes the same time to drill a 4 cable hole as a 2 cable hole and the same time to fit 25mm conduit rather than 20mm conduit, so it will cost about £20 extra to have 4 ports rather than 2.
He’s always trunked the whole thing for me (but I always have cameras and I don’t want anyone cutting or chewing through the cables). You’d probably have to agree what colour cable you wanted if you didn’t want trunking as I always get purple BT cable!
Make sure it's external grade cable too, especially so if you're not trunking. Internal grade (Inc purple stuff) is usually internal only and the sheath will degrade in the elements.Ah - will probably just go with black. Will drop him a text.
I normally use Ubiquiti UK distributors/master resellers as per the list on the Ubiquiti site.
As OcUK sell some Ubiquiti kit I won't say which ones, but I've used three so far and all have been fine with sales and customer service although I've never tried to cancel an order (just a few DOA and in warranty failures).
Let it play out, then return the unwanted item(s) under DSR. As far as I can see, almost no-one has stock of the UDM.
Since I've got rid of my servers I now have more room in the 19" rack so I moved the USG and 10Gbit switch into it. Still needs a little more work as I think I have screwed up some connections on the patch panel.
There's a patch at the back of the panel to keep things tidy, it's either that or use a 1M cable.From the look of the picture your incoming WAN1 and outgoing LAN1 both go into the network patch panel so unless you’ve got another switch somewhere, you’ll get no routing from the USG-4P.
UDM coming tomorrow now.
On a side note, I’ve seen lots of people lean towards the nanohd access point in comparison to the pro access point. Is the nanohd the way to go?
Yes the NanoHD is the AP to go for in that price range, the Pro is pretty old hat by now.UDM coming tomorrow now.
Mine all show the same since I updated to the 5.12.35 controller and upgraded them. They're all working just fine so I'm not going to downgrade them (2x24-PoE-250w, 3x8-PoE-150w).Morning gents!
My US-8-60W is showing a "downgrade" button current 4.0.69.10871 can downgrade to 4.0.66.10832 I'm not doing anything as its stable unless someone say otherwise (with a backup before hand as I have already learnt @WJA69)
