Technically no, I don't need 64GB of ram but when I last did parts overhaul I had the same response for 16GB - 8GB was more than enough. I don't update often, maybe every 5 years so I want a bit of future proofing.
Is a 7700K a big upgrade on my 6600K? capable of lasting a good few years? If so then great, Thank you.
Trying to future proof that platform for five years is trying to get that dead horse moving forward.
https://www.chrisdunnconsulting.co.uk/flogging-a-dead-horse/
Intel stagnation era four core CPUs are low end for basically any heavier workloads which might need more memory.
And any change to another quad core should have overall cost at pocket money level to make any kind sense.
Over year old Shadow of the Tomb Raider can make 8 core 9700K CPU peak at 100% load.
And next-gen consoles to be released sometime in fall will come basically with 8 core/16 thread Ryzen 3700X.
So amount of games capable to fully loading high core count CPUs will only rise.
And because of Intel's bottomless greed and anticonsumerism you can't even use such modern core count CPU of same architecture on that motherboard.
Unless wanting to hack/mod BIOS...
https://www.techpowerup.com/250109/...0-ghz-overclock-on-a-z170-chipset-motherboard
Intel's clock hasn't said tick or tock in five years, while they artificially change sockets to force people into buying new motherboard.
This year's "10th gen" is nothing more than another rebranding of that 6th gen Skylake architecture with constantly rising number of vulnerabilities.
Security of Intel's "quality" CPUs is at this level:
https://youtu.be/FcWllalgUfo?t=2m28s
https://nakedsecurity.sophos.com/20...secrets-by-starving-your-computer-of-voltage/
SGX was supposed to prevent even the highest privilege code, like OS kernel from accessing that protected memory...
And that Intel's dead horse will still be limited to 10 cores.
While AMD has had 12 core CPUs available half year and top model being 16 core...
With actually improved architecture CPUs coming in next summer and compatible with current mobos after BIOS update. (and likely quite cheaply available in fall/end of 2021)
And even with new platform we're likely going to be in DDR6 era by the time more than 32GB is needed by gamers/normal home users.
