3-slot if it's Nvidia ~60mm
Which slots though it’s board dependant, I have a few of them which I could send for postage in the new year if you like depending on leggy. It’s actually the same as just using two single non HB ribbons though so you could do that though.
Yes that's correct. Nvidia calls them 3-slot while EVGA call them 1-slot, abit confusing But it's the one with 60mm apart
Thanks, that would be great. It has to be this one so it fit the color scheme
https://tpucdn.com/review/nvidia-geforce-gtx-1080-sli/images/cards_small.jpg
EDIT: Looks like Nvidia took them down from their site Can't understand why since everyone looking for them.
Am I missing something here?3-slot if it's Nvidia ~60mm
Yes, one of them would do as long as they are 60mm between the connectors
No it must be wrong then, 1st slot is about 41mm and the 2nd 82mm (it's a 3-card one but I used the first and third slots)
20 series cards (RTX) use NVLink rather than SLI, both have different connectors.Thanks for looking.
No one ever tried a RTX link on a GTX SLI setup? Or does the connectors differs?
