This post implies I may aswell just run the Windows Balanced power plan now instead of the AMD one?
https://community.amd.com/thread/244159
I do wonder how much air actually gets in due to the front panel only having small vents at the top and bottom.
If i do as you suggest though, which makes sense, I wouldnt have an exhaust fan to take the hot air out if the case?
with your case its best to have the front fans set to a farily high rpm to overcome the lack of ventalation on the front pannel, yes it will be louder than normal but its the only way to get sufficiant airflow into the case, with regards to no exaust fan simply buy another fan to replace the other one that way you have positive airflow through your case
will do
