** OH LAWD HE COMIN' - THE KOLINK BIG CHUNGUS IS UNLEASHED **
OcUK Staff
26 Nov 2014
Stoke
Arriving before the end of the month, the majestic Big Chungus Show Case from Kolink. What an absolute unit. The Big Chungus is made of a combination of aluminium base, 1.0mm steel frame plus tempered glass top, front and side panels (no rabbit) and aims to offer a spectacular showpiece build for the extravangant amongst us. There's no less than 5 ARGB 12cm fans included, plus a pair of ARGB strips, giving you a wealth of cooling and lighting potential. The RGB can be controlled on the fly using the supplied remote control, or alternatively connected to compatible ARGB motherboard software such as Asus Aura using the supplied 3-Pin connector. There's space for a pair of 360mm radiators + a 240mm radiator at the same time for those who want to do some custom loops. There's also space for 335mm VGA cards, 175mm CPU coolers, 220mm PSU's and full sized E-ATX motherboards. The fully aluminium stands supports the I/O panel, including a fast USB3.1 Type-C port for fast connectivity. Due to the open frame design, airflow will never be an issue! Unfortunately, Dante from Devil May Cry is not included as DLC.
Frankly this is a ridiculous show case and I expect to see some suitably silly builds being created as a result. Preorder now if you want to join the church of Chungus!
Also available around the same time will be the Kolink Quantum. The Quantum has an angled front mesh cutout that has ARGB backlight, along with a rear 12cm ARGB fan for both airflow access and attractive lighting. The Quantum sports a tempered glass side panel, with space for 340mm VGA cards, E-ATX motherboards, 155mm CPU coolers, 200mm PSU's and a 280mm radiator on the front. The shroud covers the PSU compartment and also has space for 2 x 2.5"/3.5" drives, with space for a further 2 x 2.5" drives at the front, next to the motherboard. The ARGB lighting can be controlled either by the RGB switch on the front panel, or by connecting to compatible ARGB motherboards such as Asus Aura using the 3-Pin connector. The Quantum will be available at the end of the month so preorder now.
Kolink Big Chungus Full Tower RGB Showcase - Black/Red @ £209.99 inc VAT
Large Showcase by Kolink, Front/Roof/Side panels made of tempered glass, Base made of aluminium, 5x pre-installed 120 mm fans with ARGB, 2x 360 & 1x 240mm radiator support, 2 x ARGB strips included
Only £209.99 inc VAT.
ORDER NOW
Kolink Quantum RGB Midi Tower Case - Black @ £47.99 inc VAT
Stunning Midi-Tower from Kolink with mesh front and dRGB-LED strip, Supports motherboards up to E-ATX, Pre-installed 120mm fan with dRGB LEDs, Includes motherboard and I/O panel RGB controls
Only £47.99 inc VAT.
ORDER NOW
20 Apr 2015
