I have posed this question several times but not received an answer. I am running a microserver 8 with the original (2014) BIOS on Windows 7 in ACHI mode with OS on an SSD in bay 1 and 3 non-raided 6GB drives in bays 2, 3, and 4. I do not want to change the mode of operation.
Can I just upgrade to windows 10 using the Microsoft upgrade route (I have used this sucsessfully on my 3 other PCs overs the last few years.) and will it just "work" (i.e. network, graphics, etc)?
Thanks for any advice. Mel
Having trouble updating to w10 on my n54l
created a w10 usb with rufus,3 times now bios sees usb but wont boot to it,yes the usb is bootable
Am using the `BAY`bios and my ssd with w7 is working fine on the odd sata port
Nothing i have tried will let me update or fresh install even trying from within w7 desktop
Any ideas please?
Only reason i was going to try this was cos of MS dropping support tomorrow?
Would w7 still work safely if the AV was always up to date?
Its only a DL and dump pc for general rubbish/serving a few files and pcs
Thanks, Avalon.
Not expecting huge load as the server doesn't do much. But the i3 will give it a bit more grunt and unlock hardware acceleration for Plex Media Centre.
Will look at some temp monitoring apps which track temp over time to see how the g1610 is performing and then do a swap out if it looks safe![]()
I suspect you are in for an unfortunate surprise when it comes to hardware acceleration - the same one Dell R210-II owners face, that ancient onboard GPU disables iGPU use and I haven’t read anything about people being able to utilise an iGPU even though it’s just the hardware encoding features you are trying to use.
Would it not utilise the dedicated Radeon hd6350 I installed and ignore the Matrix g200 piece of crap which is onboard?
