Think its time for me to take a break from it, who the hell asked for that size of a map. Pandering again are we...
Loot isnt an issue on Erengal anymore, been like that for a while.
I really liked VikendiSomeone suggested it's one of the least favourite maps? That award should surely go to Sanhok.
You've played nothing but Vikendi since the loot table was changed on Erangel!i played erangel for 1000s of hrs. infact i played all the maps equal amounts of time. nearly 5000 in total. you know when some one says the loot is okay on erangel you just like okay then.
the loot is on erangel is the main reason people dont play it. its actually a great map but bad loot wise.
New map is an epic fail for me, not sure I’m liking the direction this is going. Sunk about 600 hours into this but I just don’t think they’ve made many meaningful changes in the last 18 months.
Never have a problem any more on Erangel, you might not get the exact guns and attachments you want every time, but you will never be without something decent.
Don't forget, the loot is 'bad' for a reason. If loot was good, then it would negate the reason for you dropping with just your wanger in hand.
If you all dropped and all had an equal chance of getting good loot, you might as well all drop fully geared... then it'll be just like any other shooter.
If you're not getting good loot, try going to some more medium>hot drop zones.
Sanhok sucks never liked it, Infact pubg sucks 75% of the time, its just that the 25% is really really good.
Still do not have much time for playing anything atm anyway tbh, is the cheating still bad or has it calmed down a little ?
