- 1 Dec 2015
@Jay85 very nice! did the owner sign up to the 4 yr warranty ?
No they didn't, it was bought for a build but never registered. Card itself is still sealed in the anti-static bag! Really happy with the price that i got this at.@Jay85 very nice! did the owner sign up to the 4 yr warranty ?
Will do a few pictures of the unboxing prior to the build
get them to register it . Gigabyte is done via person and not via Bot check . Might get away with later registration if it isn't too late
Ah i didn’t know that, so can i still register it with the cards serial number or do i need the original receipt etc as well? Thanks for the useful info.
I contemplated this one as well and the cablemods package but the phanteks one allows me to move the mount up or down so depending on my setup it gives me that flexibility to change the gpu’s position.
Does it just touch then or actually rub against it?
Messaged the guy so hopefully i can get the original receipt then and register it. Whats the standard warranty then without registering?need the original order. if you can get the person you ordered it from to do it, should then be able to claim 4 yrs. bit of a grey area that that rep on here touched about .
touches, gpu is pushed about 2 degrees off center but all fine . Xtreme ram kit prob tallest on market
I know what you mean, i’ve clear fluid for the past 6 years and tbh i really want a change. Tell you what though, there has been zero corrosion on all my blocks using de-ionised water for years. My Bitspower EF summit is still crystal clean! Lets see how she fairs with mayhems pastel and some dye for the next 6 years again haha.does look stunning!
found personally just using clear fluid works best with RGB and looks clean . And with glass is just magical
So i registered it today without the original receipt, i used the paypal invoice i got from the transaction and the warranty has been confirmed now with the 4 year instead of 3. Is there anything i'm missing? Does this email act as an official confirmation?@Jay85 very nice! did the owner sign up to the 4 yr warranty ?
I dont know when the card was actually bought as the seller didn’t tell me. i just registered it using the receipt from when i bought it haha. Seems to have worked?@Jay85 long as its been registered etc should be fine. any issues then Rep on here can assist
was the card registered past the 30 days from when the card was first bought ?
Was quite surprised it had qualified just like that, only took 15 mins ish for a confirmation to come back.guessing over 30 days then, and shows Gigabyte is flexible - wouldnt stand a chance with zotac if your late
