Mate, I really enjoy it and he has now brought NVidia's shield in to defend his way of thinking. DLSS wasn't great from the off and it did look like vaseline had been wiped on the screen at times but since then, NVidia have got on top of it and it is much much better. I genuinely look forward to what he is going to post next and unlike Melmac and TNA, I have no chance of 'resisting'![]()
You know nothing.
Thanks but it doesn't matter. I will always prefer the AMD image because to me it looks with higher texture resolution, nicer colours, and AMD works on technologies like Radeon Image Sharpening and FidelityFX, while nvidia does the opposite - introduces DLSS..
LOL what a joke. The colours can be made look the exact same on both AMD and NVidia.
But at least we are getting to the truth now. There is no difference in image quality, You are only seeing what you want to see.
Are we really arguing over the difference in a zoomed in 4k image and a pixel difference here or there? That top image doesnt really look any different to the image below. Both are a bit blurred i see the same details across the board with very little difference. Probably because like me you gone messed up and put the 590 image twice.
I also ran cards side by side and on the same monitors and suspect you are searching for something that either isnt really there or simply has so little impact that after looking for 5 mins I can bearly see what you are trying to prove. By extension you are basically feeding the thread with more images where the two are broadly comparable.
I can see the differences easy enough between the two. The veins on the leaves are easier to see on the AMD image and some of the lines are much clearer. Would this be noticable while playing and zoomed out i doubt it. Guy in the video pointed it out as the biggest difference in all games tested. The Nvidia image overall is just that bit more blurry again though zoomed out would i notice.
I dunno if I agree that the colours can look exactly the same, near as damn it but, and i have said it a few times in the thread, I also like the AMD presentation better. I can't put my finger on exactly what it is but to me it just looks better, a bit crisper and a bit more vivid, again though preference and opinion are massive factors here. I can tune the nv card to look very similar but I can't seem to get it looking exactly the same.
Our brain tricks us in so many ways. Have you ever used a monitor calibration tool?Problem with that is they aren't then the same frame so can we compare where the frames are different? we know it isn't the same frame as the position of the flag against the branches is entirely different, at least in the screenshots. Perhaps I need to watch the video.
I think your sentence about preference is the important one.Our brain tricks us in so many ways. Have you ever used a monitor calibration tool?
I can see the differences easy enough between the two. The veins on the leaves are easier to see on the AMD image and some of the lines are much clearer. Would this be noticable while playing and zoomed out i doubt it. Guy in the video pointed it out as the biggest difference in all games tested. The Nvidia image overall is just that bit more blurry again though zoomed out would i notice. The easiest way to see it is open the 2 pics in different windows and click back and forward between them. Just staring at them is much harder.
I'm amused at the thought of people revisiting that video again and trying to find differences when he said there's no real difference between the two at the end of the vid. Some guys really go to the nth degree dont they
@4K8KW10, did you like my blurry ass washed out screenshot from CS Source? let me know your thoughts mate. I'm interested.
It is getting boring now @4K8KW10, it is fine to post an opinion but to not engage or back it up when engaged is trolling. Final warning.[/Q
Well, I started to dig into this deeper after trying to play with a GeForce. The lower resolution textures are most obvious when one is in gameplay, in static imagery it's still pretty visible but it doesn't look as bad as when the images move.
Also, if we think logically, if AMD throws more hardware resources at the problem, why are still GeForce in the worst case on par? It makes no sense. The GeForces should be slower.
Look, for example at the newly released RX 5600 XT and RTX 2060 KO:
ROPs/TMUs - 64/144 vs 48/120
Pixel fillrate - 116.5 vs 88.3
Texture fillrate - 262.1 vs 220.8
Memory throughput - 357.1 vs 399.4
vs![]()
Price:
vs![]()
Performance - the same:
https://www.techpowerup.com/review/sapphire-radeon-rx-5600-xt-pulse/27.html
i would give this up because as ppl have said THEIRS NO REAL DIFFERENCE AND YOUR gonna get banned is it worth it ?!?!.
