Tomahawk B450 w/ 3900x
6 Jun 2008
Finland
Keep good case airflow especially if you have hot high end graphics card dumping lots of heat into case.
Fortunately gaming doesn't load high core count CPUs as heavily as 3D rendering etc.
But full CPU load heating up VRM and at the same time some 250+ W like of heat from graphics card into case could fast cause quite hot temps.
OP
14 Apr 2009
Cheshire
So tempted by this board as it seems to be almost the board of the decade. Ok maybe not, but it seems might impressive.
Ill likely build it into my massive thermaltake x9 case which has a few fans all around.
22 Nov 2018
It would be silly to underspend on the motherboard if you're buying a 3900x.
It would be different in 5 years time when 16 core chips are going for £100 on the used market and you have a Tomahawk B450 laying around. That's the kind of thing I'm panning to do in the future when my 2600 struggles because I bought the Tomahawk especially so I can do a future CPU upgrade.
OP
14 Apr 2009
Cheshire
But if it runs the chip, and I don't need any thing else mobo wise, wouldn't it be silly to spend anything more?
X570 are expensive to get a decent one.
22 Nov 2018
Yes I agree 100% that the X570 motherboards are very expensive. Yet I also think 12 core CPUs are very expensive as well.
I just think it makes sense that a CPU should cost twice as much as a motherboard. Also a graphics card should cost twice as much as a CPU. Then it's evenly matched. So a £250 motherboard + £500 CPU + £1000 GPU. Or a £100 motherboard + £200 CPU + £400 GPU.
If you're on a budget and need a 3900x then why not get a used X470 with good VRMs?
15 Oct 2019
Uk
The tomahawk can handle a 12 core better than some of the budget x570s, I'm planning to stick a 4900x into mine next xmas.
Here is an excellent guide showing which motherboard can handle which CPUs at stock and overclocked.
https://docs.google.com/spreadsheets/d/1d9_E3h8bLp-TXr-0zTJFqqVxdCR9daIVNyMatydkpFA/htmlview
14 Aug 2018
Anyone doing this?
Success?
Yes, I've done it and it was perfectly fine. Especially once the newer AGESA was out. The only issue I had was that the DRam voltage was not set to the correct 1.35v when using XMP (defaulted to 1.2v so had to set it manually) but that may well be fixed now as I had mine around 3900X release date.
OP
14 Apr 2009
Cheshire
So many say buying this board for the 3900x makes no sense due to the pricing disparity. To me it seems logical. I also have a dedicated sound card ae-5 so have no care for audio.
1 m.2 is fine as well.
Think I'll do this.
1 Dec 2015
Think I'll do this.
As long as you understand the other limitations then the B450 tomahawk is a good choice.
I had to retire a couple of old HDD as I ran out of SATA ports (coming from x99)
OP
14 Apr 2009
Cheshire
I guess I have to ask. Other than crap sound, no pci 4,1 m.2, not a lot of Sata, what other limitations are there?
14 Aug 2018
It has 6 x SATA3 which is pretty much standard on all newish motherboards. My Z390 ROG Max XI code has 6 as well as my X470 and so does the X570 Aorus Master.
It's a great board and apart from the odd few points in benchmarks you won't notice the difference in performance with X570 boards, plus you miss out on not having a fan on your chipset. Just partner it will some cheap E-die 3200 C16 and you're sorted.
OP
14 Apr 2009
Cheshire
Already got my teamgroup 3600 c16 sitting in a draw.
I think I'm ready.
I have a budget and I'd rather do 3900 and cheap board than expensive board and 3800.
Will use stock cooler.
15 Oct 2019
Uk
I think I'm ready.
The main reasons to get an x570 is pcie 4 or you want a 16 core and love overclocking or have a money is no object budget, other than that then get the tomahawk, if you need an extra feature the tomahawk doesn't have then get the 450 pro carbon or an x470.
OP
14 Apr 2009
Cheshire
Pro carbon would look a bit odd in my massive x9 case.
48hrs and I'll have made a decision... I'm sure!
