Hi, I am about to build a new Gaming/VR PC and would like input on storage design. Can anyone help or recommend solution
1. For resilience, Im thinking I would mirrored OS disks with 2x M.2 NVME devices RAID1'd - Will this reduce performance, enhance performance or be exactly the same as 1x M.2 NVME (I dont want cost / MTBF taken into the consideration, just performance and impact on overall system)
2. If I went with the solution above, is it normal to then have 2 tier of storage using more traditional SSD and then third tier of storage for large volumes using spinning disks
Rich
Rich
