- 13 Jan 2010
- Manchester
Can't beat the silence
Tldr water cooling is not for poor people.
Going by that video it's a bit of a let down as it doesn't really gain much more performance at all, the nitro can boost to 2010mhz too
It's not for anyone tbh. Other than people who want to show off their rigs.
Expensive to buy, expensive to run. No real benefit over top end air cooling apart from slightly quieter or silent.
Nope!
My rig isn't on show. No maintenance in over 2 years, so costs nothing extra. If I wanted to, I could clock higher as well, because I'm not restricted by heat.
Have you ever water cooled? I'm guessing not. I'm sure you just make things up just to talk to people![]()
I'm going to watert cool my next GPU. I'm so sick of manufacturers using crap fans on their coolers that sound like jet engines
Yep, pay £100s (or £1000s if you buy nvidia carda) for a gpu and get the cheapest fans the manufacturer can find :\
Don't buy bottom end card.
The answer isn't spending £500 on watercooling gear.
It's spend another £20 and get one with a decent cooler on it.
Mine is silent.
my 1300 pound Asus strix 2080ti is rated as the quietest 2080ti on the market yet sounds like a jet engine.
All of them have bad fans. If you can't hear it, it's because the rest of your case is even louder or you have headphones on
I've been watercooling for nearly 15 years now and yes it can be a pain in the arse and more involved but for me it's worth it mainly for the noise levels.
If you already have a custom loop for your CPU and have enough rad capacity then add the GPU to the loop.
Your card likely runs hot.
My card runs at 59c whilst playing pubg. Which isn't a friendly game to play. Fans are still silent.
2070 super jetstream.
What temps does your card whilst benchmarking or playing a brutal game?
