Does anybody know of any decent brands of reasonable looking cabinets designed for these ONTs to be installed into? Openreach have done away with the combined Huawei ONT and battery backup in a reasonable small box and now you just get a smaller single port ONT stuck on the wall and they leave a loop of fibre flapping around underneath it and call it a day. Back when the installations were a 4 port ONT and a battery backup without any sort of enclosure some house builders would chuck everything into a box, like the below image I stole off the Internet:
I guess that's 19" across and the holes are threaded in case someone wanted a patch panel, but it doesn't really matter. There's a couple of metal options with holes cut in them available which look pretty awful, and I'd rather not try and adapt something from Ikea because then people will say "why is there obviously a medicine cabinet so low down on the wall in the hallway".
The USA and Australia seem to have had the concept of a structured media panel from people like Leviton which never really caught on here, I guess because cable TV isn't generally as common. Anyway, if people know what the above box is called I would be grateful.
Edit: And of course what happened was my next search found the exact product https://www.prysmiangroup.com/sites...ownloads/datasheets/WM038-08 Home Hub Box.pdf
It's a bit huge though, so I'm still looking.
