- 22 Dec 2018
I currently have a desktop based on Asus Z370-g mATX, Intel 9600k, EVGA RTX2080xc, two Corsair Vengeance 16GB 3,000 MHz ram sticks and Samsung 970 pro SSD. For 1080p gaming I have no trouble. But if I set resolution a little higher using the Nvidia feature (Super sampling or something like that) and set two a bit higher than 1080p then the frame rate can drop on some games like FORZA horizon 4 l, and GTA V is terrible, mainly things like plants and foliage cause this. But if I select full 4K resolution FPS can go down to 30s, I can get back to barely 60fps if I lower graphics settings but I have to lower quite a few which kinda defeats point of high resolutions. I know the CPU is the weakest link and been thinking of upgrading to the 9900k. But wondering if I should consider saving and getting a z490 board and CPU. The reason, I’m hoping I could get good improvements by going for maybe the second or third ranked cpu rather than the highest spec’d one. But I know the 9900k will give huge improvements from the 9600k, but how long would this still be adequate for future gaming? Maybe I’m worrying too much, but thought my GPU would cope better at higher resolutions, if I know the 9900k will make a good difference then I’ll just do that. I’m guessing the 2080ti will just get throttled. As a ‘clutching at straws’ option. Would adding another 16Gb ram stick make much difference? I ask as prices are dropping, or maybe get faster ram? What’s people’s thoughts and thanks in advance for you’re replies.
