- 8 May 2018
- Newcastle Upon Tyne
My PC keeps turning on and instantly off (Everything lights up then goes out). I have checked the CPU and it looks fine and checked connections to everything and again looks fine so I can only imagine it's the power supply. Just want to make sure i'm getting a decent one and the correct one for my setup.
Also, if anyone believes it to be something else other than the power supply, any advice would be welcome.
This is my current set up:
HS-00A-CY Cryorig M9I Single Tower Heatsink for Intel
CA-22Y-BX Bitfenix Formula Series 550W 80 Plus Gold Power Supply
HD-044-TS Toshiba 1TB P300 Performance Hard Drive (HDWD110UZSVA)
MY-088-TG Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-19200C14
2400MHz Dual Channel Kit - Grey (TLGD416G24
MB-6BX-AS Asrock B360M Pro4 Intel B360 (Socket 1151) DDR4 Micro-ATX
HD-005-TG TeamGroup 480GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid
CP-63S-IN Intel Core i7-8700 3.2GHz (Coffee Lake) Socket LGA1151
GX-045-PL Palit GeForce GTX 1070Ti Jetstream 8192MB GDDR5
Thanks
Thanks
