Need Help Choosing RAM
1 May 2003
I am really stuck on which RAM for my Ryzen build, I have the 3900X and Auros Ultra motherboard.
32GB is my preference, I run a lot of VM's for various tasks.
I would prefer 2 sticks over the 4, which rules out 8 Pack, I am not overly keen on Corsair Vengance, seen more bad than good.
Appreciate any assistance here :)
Over 100 views and no replies?
My hardware has turned up, just waiting on the memory.
I have looking at GSkill Flare X and Corsair Dominator as two potentials, but it seems to be a lottery on Samsung or Hynix.
My 2 cents on this is ... just get some 3600 CL16 .. .or 3600 CL14 memory ... don't get memory that is 4000+ and then try to fine-tune it because you'll have a loooot of headaches with it :D
As for brand ... You have the TeamGroup ARGB 3600CL14 that are just cute! :D
That Team Group T-Force Xtreem ARGB mirror finish does look nice, shame they only come in 8GB sticks only.
CMT32GX4M2C3200C16 - seems to be the winner and they're available, unlike the GSkill Flare X.
Also 3200MHz CL14 is sure to be good bin B-die and are the cheapest such.
But not all 3600MHz CL16 is B-die.
G.Skill's 16-19-19 kits are some Hynix factory overclocked to max. (or possibly lower bin B-die)
3600MHz 16-16-16 kits are B-die.
You'll recognize them from price...
You're right but (as I understand) Dual Rank sticks put more pressure on the memory controller so are sub-optimal for overclocking.
Two DIMMs per channel also makes two ranks and is equally heavy for memory controller.
And it's also more demanding on motherboard's DIMM slot wiring.
Usual "daisy chain" wiring gives clearest signaling for only one DIMM per channel.
That makes 2x16GB better most of the time than 4x8GB.
And while there should be some 16Gb DDR4 DRAMs which would enable single rank 16GB DIMMs, those DRAM chips are eaten by "too much isn't enough" memory demand of servers.
I picked up BLS16G4D32AESB for £50, this will tidy me over as I am going to the states in 12 weeks.
I can collect some F4-3200C14D-32GTZR or F4-3600C16D-32GTZN when I am there
my 2 cents is that I bought the 8 pack and the heat spreaders are high - so consider the cooler going ontop
I think 8Pack has mentioned elsewhere that the top of the headspreader can be easily removed and at no detriment to cooling. I guess aesthetics could take a hit depending on what angle you look at them from but not if the CPU tower cooler completely covers them.
Might have referred to a specific model though.
yes 8 pack did mention that the top of the heat spreader can come off and if you need even more clearance then I think that the heat spreader can be fully dismantled.
