Forget it. No point.
When did this become AMD vs Nvidia or AMD vs Intel? It's about watercooling.
Where did I say I didn't like watercooling?
It isn't about a company it's about HEAT. THE biggest killer of hardware ever.
Yeah in my example 3 x 3.6wSo 3 fans would be 10.8w of power from the cards max that can't be used in the core or memory.
Would be 10.8w
Not saying that fans are that though
Was just the example
That popped in my head at the time
And not sure if a card rated say
250w would mean
250w minus 10w for fans
Or 250w +additional 10w for fans
could be rightFrom watching a YouTube vid (JayzTwoCents I think) the fans draw from the card max, so if it is 370w that includes the fans, RGB and everything else on the card.
?Interesting discussion - a few points. Fans for WC are likely to be running slow (this is after all the point) so the discussion on whether WC draws more power based on fans alone is, frankly, odd. Over and above air you have a pump - that's it. Personally I'd say this isn't worth discussing - it's negligible.
Heat however is not - WC does absolute wonders for this and for GPUs full blocks drop heat massively vs air across the whole board (VRMS are super toasty) and yes this will make a difference to the clocks you can hit (consistently even in hot weather) and the longevity of components. You can move heat away from things far faster (and in my build to an external rad which means i'm not dumping hear into the case at all) which also stops surrounding components for getting hot too.
Noise was the real reason I started on the moist path - well over 10 years ago - and my current rig was built and 'run in' on air. It's a lot nosier. A lot. I admire the progress that air cooling has made but it's intolerable for me.
Would I recommend it? No, not generally. If you enjoy a challenge and like building stuff (I do) then it can be rewarding but there's a lot to learn and a fair bit that can go wrong until you do. The reward is a cool quiet system but it costs time and money to do it right. WC components do last a long time but they cost a fair bit nonetheless.
That said why justify doing something you love, especially on a forum filled with idiots spending vast amounts of cash on overspecced PC equipment?
where did i say fans alone?
you could argue why bother spending £300 plus an additional £20 a year in electricity to protect components which after 3-4 years are worth pennies.
the average pump draws 25W and some people even use 2 pumps for the bigger radiators or custom loops, etc.
now 25W isn't a huge amount but it's substantial enough to impact long term costs over air.
At 25w it's only £20 a year if you have 2 pumps and use your system for atleast 6 hours every day. I would argue that the majority of users don't have 2 pumps.
Your watercooling will last much longer than 3 - 4 years though. Your initial cost may be £300 but it will last you multiple cpus if you choose. Other than my full cover gpu block and my cpu block that I changed out of choice the rest of my components bar tubing are 10 - 15 years old and still going strong.
Obviously it's not clear cut but that's why I said it can last your years if you choose. It just took 6 hours has an example, people will use their pcs less and others will use them a lot more. People like your friend who just leave their oc on 24/7 obviously aren't bothered about the power consumption so an additional £20 or so a year would probably go unnoticed.
Full cover gpu blocks will only last you for the life cycle of the gpu but a cpu block can last for aslong as your choose to keep it and if you get a board in the future with a different hole mount layout more often than not you can get a mounting bracket to fit your board and block. Yeah a lot of people change their blocks with every build or upgrade but that's generally a choice their are making rather than a necessity.
