Need a car with loads of boot space
15 Apr 2012
UK
I need a second car for trips to my man cave in the highlands. A 7 seater would be fine as long as I can get as much space as possible when all the seats are down. I would need around 7 feet or enough to lie down in the back. A van is out as I have a 9-year-old daughter who can’t sit in the front.
Any suggestions? Have around 6k to spend.
got to be the mondeo estate, mondeo is the biggest saloon / estate at that age i think
The Skoda Superb is quite a bit bigger both in the older and especially the newer models.
Latest models
Ford Mondeo Estate 500 litres seats up, 1605 litres seats down.
Skoda Superb Estate 660 litres seats up, 1950 litres seats down.
2012 models
Ford Mondeo Estate 542 litres seats up, 1733 seats down.
Skoda Superb Estate 633 litres seats up, 1865 seats down.
there is the issue of 'usable' space.
.. can't see superb, but mondeo estate https://www.ridc.org.uk/features-re...ndeo-turnier-20-tdci-titanium-5dr-estate-2016
BOOT
Length of boot floor - back row of seats folded down or removed
1931mm
Length of boot floor - back row of seats upright
1112mm
Vertical height of boot opening
711mm
Boot sill height to floor of car
0mm
Boot sill height to ground
602mm
Width of boot floor at narrowest point
1044mm
Width of boot opening - bottom
1104mm
manufacturers should adopt, the din standard, is it ?, which gives some idea of suitcases you can get in.
this man cave has bootleg spirits ?
