- 29 Sep 2010
so I’m hoping to put together my loop this weekend, it’s going to consist of a 360mm, 280mm and a 120mm rad, cpu and gpu cooled. Powered by a d5 in a heatkiller d5 150 res.
Now, when the pump res is fitted it’s probably going to be quite difficult for me to reach the speed on the pump as it’s going to be floor mounted with the decoupling kit.
I noticed that it’s a Vario with a 1-5 option on the pump, what do you recommend setting it as? Can I set it to 5 but then control it via the motherboard if it’s too noisy?
