8k 60fps Benchmark
26 May 2014
Dont know what's up with MyBrains rig, but my sig rig plays it flawlessly. CPU at 2% utilisation and GPU at 75%.
Probably a lot of peoples internet connection too. I'm running a VM 350 connection. It seems to be pulling about 70 Mbps, so a beefy connection is needed.
You're running it with hardware acceleration enabled, so the graphics card is doing all the heavy lifting. What was being discussed is running it entirely on the CPU with hardware acceleration turned off - an area where Chrome seems to have problems, but Firefox doesn't.
Permabanned
27 Sep 2019
Ok times moved on so has Edge Chromium builds, I can now play it smoothly (before I had to use old Edge) and skip forward/back and play instantly with or without Hardware Acceleration so CPU or GPU based. :)
OP
6 Feb 2019
Go into advanced settings and it’s an option there.
3950x & 2080ti
Hardware Accel Off. I accidentally cut off the GPU usage on the first image, but it basically just idles when hardware accel is off. GPU usage is misleading anyway. With hardware accel on, task manager looks like the GPU is running at 72%, maybe it's using that many cuda cores, but the core speed and power draw is low - the GPU is only pulling 80w out of a possible 330w - I suspect the 2080ti would be able to handle 16k 60fps playback too, but that would cause very high power draw
Hardware Accel On
5 May 2017
3950x & 2080ti
Hardware Accel On
Ok nice but how was the experience? Was there Ani problem during playback? Was it 60 fps (when hardware accelerate was off)?
