- 31 May 2009
You don't understand the difference between Coffee Lake/Pinnacle Ridge and Matisse's boost behavior. Coffee Lake/Pinnacle Ridge's single core boost clock is practically guaranteed on any or all cores if the cooling solution and power delivery are good enough. And the boost clock is sustained for much longer (indefinitely if the cooling and motherboard power delivery is good enough). Matisse's boost clock is only guaranteed on one core and it is sustained for much shorter times, so short that many times it is never seen at all. I've tested with a 3600 myself and was let down by the results (one core reaching 4.175 GHz and none of the others going over 4.05 GHz on water cooling running cinebench).
It's still a great CPU but it's clear that the new definition of boost clocks was done to maximize yield at the expense of consistent core quality.
By comparison, all the cores on my 1600X can hit 4.1 GHz when boosting with just MCE (MSI's version) enabled.
When did you test this 3600, and with what agesa and exactly what awful water cooling solution?
Did you for interest sake, test it with the supplied cooling for comparison?
Given that the wonderful company Intel don't seem to supply an cooling at all now, given their complete and utter ******** TWP ratings.
. My R5 3600 is purchased at launch from OCUK, you'll see
