- 19 Jun 2012
On the graphics the William's and Toro Rosso have changed colours.
Blagging my head that is!!
10.4 Steering :
10.4.1 Any steering system which permits the re-alignment of more than two wheels is not permitted.
10.4.2 Power assisted steering systems may not be electronically controlled or electrically powered. No such system may carry out any function other than reduce the physical effort required to steer the car.
10.4.3 No part of the steering wheel or column, nor any part fitted to them, may be closer to the driver than a plane formed by the entire rear edge of the steering wheel rim. All parts fixed to the steering wheel must be fitted in such a way as to minimise the risk of injury in the event of a driver’s head making contact with any part of the wheel assembly.
10.4.4 The steering wheel, steering column and steering rack assembly must pass an impact test, details of the test procedure may be found in Article 16.5.
It looks like the kind of system you'd want to get test data on, not least proper driver feedback on how it feels in use. Even if the other teams manage their own implementation, Hamilton and Bottas will have the benefit of time on track experimenting with what this new system can do for them.
It's not just me then!On the graphics the William's and Toro Rosso have changed colours.
Very well-played Mercedes. Now let's see if it does indeed work. If it does then presumably that have a whole lot more strategic options on pit stops, especially if they qualify high and race high up the field.
Better tyre operating window, less tyre wear, quicker on corners and straights. Even small gains in any of these areas will be huge. This is without considering their innovative rear suspension and updated PU.
Indeed. Out of all of those, tyre wear is the real big advantage for me, if it delivers as much as it promises. The ability to go longer, or to go 0.5 second a lap faster for the same time, will be massive. Hamilton has been a master of these Pirelli tyres - he should take full advantage.
It was already outlawed in the 2021 regulations, so this will be the only season we see it. Whether the FIA closed that loophole from existing discussions with Mercedes about the legality of this or whether they were intent on closing existing loopholes anyway is anyone's guess.
Without rear-facing camera we don't even know the extent of what it does yet. Does it also affect the rear wheels?
The FIA's aggressive approach to banning innovation is a problem for the sport. I can't think of a single good reason that this should be disallowed.
1:15.7 from Bottas. If Mercedes are still bluffing then this season is going to be a long one.
In worse news for Mercedes Latifi's car has just lost an engine. Red Flag. Sounded like the ICE.
Because it adds nothing to the sport other than driving up costs unnecessarily.
It is great to see such innovation, but if that innovation forces everyone to spend probably 10s of millions to develop such a feature themselves then it's hard to argue against it being banned.
Pole last year was a 1.15.4
3 tenths off in testing is ridiculous if they arnt pushing
It hardly challenges the drivers! It's not like it makes the car hard to drive on the limit or anything. Like I say, it's not relevant to road use and it doesn't make the sport any more enjoyable to watch.If you're going to dismiss a system that helps manage tyre lifetimes and requires driver skill to do so as adding "nothing to the sport", I'm really not sure what kind of innovation you think should be allowed. However much it costs other teams to add, it should be less than it cost Mercedes to develop. That's the nature of innovation.
