- 10 Sep 2003
- Midlands
The pork tinga looks godly. What gear to I need to make that on the Weber kettle?
What do you guys use in the bottom of your smokers to catch the drips?
I put together a UDS and it's a nightmare to clean out.
I've used a fairly cheap and cheerful one and it did the job quite nicely but it rather depends on your budget, you need to spend a fair amount to get one that is made of nice thick metal, seals nicely with no leaks; otherwise you'll need to do some smoke tests and fix up any leaks with aluminium tape or similar.does anyone here use one of the offset smokers? I quite fancy getting one as they seem pretty versatile in what you can get out of them but just wondered if anyone has experience of them...
Would have thought there'd be a bit more content in here what with everyone staying at home and this good weather!
@Street - BBQ Vortex - yet another BBQ gadget that I never knew I needed but now want! How long are your chicken wings taking to cook in that? I have to say I think some Jerk chicken thighs using this method would be insane. What wood are you using in the middle? Lump of 2x4 from B&Q yeah?
@Street - I’ve got some of the coal separators somewhere, but I presume the advantages of this are a more even heat and also a more intense heat source?
You'd think that the smoke doesn't penetrate but it really does. Never had a non smoky rib and always get a good smoke ring! Always done it that way, but don't discount other peoples' opinions. Many ways to skin a catEnjoyed the video, still not getting the rationale behind foiling the ribs from the start though? Not like you were in a hurry to cook them? And as much as I want to take your word for it, it doesn't really make sense that the smoke will penetrate just as much?
