- 10 Nov 2006
- Lincolnshire
Had this once yesterday as well, just thought it was a game doing it maybe rivatuner but now I'm not so sure
Hi, twice now my monitor refresh rate has switched to 85Hz in Windows 10 desktop and the colour to Y**4:2:2 and Limited range... trying to set it back to RGB does not work; and no higher refresh rates exist above 85Hz.
Rebooted the PC and it is back to normal - 160Hz, RGB and Full range...
I am using the DP cable that came with the monitor.
My graphics card is an Asus RTX 2080 Super EVO OC
Any ideas what is going on here please?
Does anyone play PUBG on this monitor?
What DPI setting is your mouse for PUBG?
I tried 800 and it was far to slow. I currently use 1200 but still feel like I should increase it a little.
Man this monitor is so much better than my old Asus XG438Q!
Colors just pop and are more vivid and the image looks a lot better even though the contrast ratio is much lower than that Asus XG438Q I have. And the best part is the response! Omg this monitor is blistering fast, it leaves the Asus for dead with all the bloody black smearing the XG438Q has!
Very happy with the upgrade.
Also, people having issues with the monitor switching to 85hz 422, I think it happens when the monitor has been idle for too long and goes into standby from windows. When it comes back on, it does so at 85Hz. Probably just a bug and not any fault to any hardware. Anyways, this is how it happens for me, I can avoid it by making sure the monitor does not goto standby mode. Always stays at 160Hz 444 in that case.
Pretty sure you’re the same person who emailed me at TFTCentral pondering this upgrade. I’m pleased to hear you were happy with the change!Man this monitor is so much better than my old Asus XG438Q!
Pretty sure you’re the same person who emailed me at TFTCentral pondering this upgrade. I’m pleased to hear you were happy with the change!![]()
Following on from your previous correspondences with my colleague, Remi, when he said that he would like to invite you to raise a VOC for this, he means that we would like your permission to write-up an internal report to raise a suggestion for this software update to the relevant department at Head Office.
This will allow us to try and get an update delivered for this specific Monitor model to rectify this issue for you, if we manage to raise enough of these VOCs.
If this is something you would like me to go ahead with.
I regret to inform you that we do not have a reference for this specific issue, we have simply explained to our Technicians the best course of action to take.
However, you do have a reference for your correspondences with our agents, which I can provide you with.
CNU200225934327
In regards to a time-scale to fix this issue, this would be an internal process that is undertaken by a member at Head Office, who will investigate and inspect each case carefully.
If we receive enough demand for a software update, then our developers will be asked to produce a solution for this.
You may not receive a response from this action, although in the event that something does happen, I will be the first one to let you know.
If you know anybody with a similar issue, please inform them to send us an email or to give us a call so that we can raise another VOC for this cause. That way, we will be able to generate enough demand to fully rectify this issue.
Yeah read a page or 2 back buddy, we've been talking about it
