AMD processors from 2011 to 2019 vulnerable to two new attacks
22 Nov 2009
Under the hot sun.
17 May 2004
Home
AMD defence force.....assemble :p
Your comment would be mildly amusing if it wasn't for the fact that prior to November 2019 I had Intel hardware. A Core i5 3570k which served me well for years. I moved to AMD because there's no denying their superiority right now. I'd have been a fool to buy Intel. Especially with all of their current security flaws.
15 Jun 2005
Edinburgh
No need. Because the day this ludicrous paper came out the one bellow was published also.... But somehow was "missed" I wonder why :rolleyes:
You mean the one we discussed two days ago?
https://forums.overclockers.co.uk/posts/33399627/
This paper originates from the same University (and some of the same researchers) who discovered the Meltdown & Spectre vulnerabilities. But this AMD focused paper is deemed "ludicrous" and the work of Intel shills. :rolleyes:
1 May 2013
M28
Researchers find new Intel security vulnerability that is “impossible to fix”
https://www.kitguru.net/components/...rity-vulnerability-that-is-impossible-to-fix/
Panos pwned :p
Also, 'no need'. So it does exist ;)
22 Nov 2009
Under the hot sun.
Panos pwned :p
Have you both understood what this vulnerability is on the AMD? They isolated the L1 design and simulated an attack. Ignoring completely the rest of the CPU how would react on such attack. That is why is ludicrous.
Thats is far different than exploiting the CPU as a whole as happened with Intel.
In addition point the coincidence the same day post papers were released. One with a critical flaw (Intel) that cannot be fixed, the other that can never happen.
Ofc it would be my bad, spending my time in a technical forum which average member has no clue of what he reads....
Permabanned
OP
27 Sep 2019
Humbug take of your rose coloured glasses, the results are from the same source as the Intel flaws, you cannot choose to believe one set of results and not the other because it fits your agender, Panes post means nothing as it does not matter if this will effect many people or not as the Intel one will not effect home users.
So Panos is now an scientist/engineer who understands CPU/GPU architecture?
28 May 2007
TBF, you can’t seriously compare this to the Intel report.
Permabanned
OP
27 Sep 2019
I never said I was, does it matter what is more an issue than the other both are issues and again will not effect the majority of home users.
Like someone above stated, when its Intel bring out the pitch forks and when its AMD its not a big deal...;)
3 Oct 2013
To be fair they do say that they have reversed engineered the l1 cache hashes which are undocumented. so it's simulated to the extent of what they have managed to find out.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
They didn't attack the CPU, they ran a simulation on the L1 Cache, that's like simulating an attack on a vault by simulating a bypass on the inconvenient vault door.
I can simulative starting your car if a ignore the key.
Man of Honour
13 Oct 2006
LOL.
Funny enough when it was pointed out the other way around with other flaws certain people wouldn't have it! infact I took quite a lot of **** posting from certain people who are posting in this thread for pointing out the same kind of thing and purely from an academic perspective on my part (I even pointed out at the time how it could go on to be a bigger issue).
And a reminder that some of these Intel flaws were built upon baby steps consisting of exactly what you are talking about - not to say that applies the same for AMD necessarily but don't forget that factor.
9 Nov 2009
Planet Earth
If people are petrified over this,they would be even more petrified about the latest Intel flaw,which is not apparently fixable:
https://arstechnica.com/information...psets-have-a-concerning-flaw-thats-unfixable/
5 years of Intel CPUs and chipsets have a concerning flaw that’s unfixable
Converged Security and Management Engine flaw may jeopardize Intel's root of trust.
Also,Intel also had an L1 cache flaw discovered in January called CacheOut:
https://www.theregister.co.uk/2020/01/28/intel_processor_data_leak/
https://www.pcworld.com/article/351...ntel-processors-with-a-fix-arriving-soon.html
AMD is not vulnerable to that L1 cache flaw though. However,Intel was given prior warning though so they could try and attempt some fixes.
21 Sep 2018
Cacheout bypasses mitigations for Fallout and Zombieload. No known fixes for it yet.
