Quick everyone jump back to intel
AMD defence force.....assemble
You mean the one we discussed two days ago?No need. Because the day this ludicrous paper came out the one bellow was published also.... But somehow was "missed" I wonder why
https://forums.overclockers.co.uk/posts/33399627/
This paper originates from the same University (and some of the same researchers) who discovered the Meltdown & Spectre vulnerabilities. But this AMD focused paper is deemed "ludicrous" and the work of Intel shills.
Researchers find new Intel security vulnerability that is “impossible to fix”
https://www.kitguru.net/components/...rity-vulnerability-that-is-impossible-to-fix/
Panos pwned
Also, 'no need'. So it does exist
WTF are you talking about?
Humbug take of your rose coloured glasses, the results are from the same source as the Intel flaws, you cannot choose to believe one set of results and not the other because it fits your agender, Panes post means nothing as it does not matter if this will effect many people or not as the Intel one will not effect home users.
So Panos is now an scientist/engineer who understands CPU/GPU architecture?
I never said I was, does it matter what is more an issue than the other both are issues and again will not effect the majority of home users.
Like someone above stated, when its Intel bring out the pitch forks and when its AMD its not a big deal...
Have you both understood what this vulnerability is on the AMD? They isolated the L1 design and simulated an attack. Ignoring completely the rest of the CPU how would react on such attack. That is why is ludicrous.
Thats is far different than exploiting the CPU as a whole as happened with Intel.
In addition point the coincidence the same day post papers were released. One with a critical flaw (Intel) that cannot be fixed, the other that can never happen.
Ofc it would be my bad, spending my time in a technical forum which average member has no clue of what he reads....
5 years of Intel CPUs and chipsets have a concerning flaw that’s unfixable
Converged Security and Management Engine flaw may jeopardize Intel's root of trust.
If people are petrified over this,they would be even more petrified about the latest Intel flaw,which is not apparently fixable:
https://arstechnica.com/information...psets-have-a-concerning-flaw-thats-unfixable/
Also,Intel also had an L1 cache flaw discovered in January called CacheOut:
https://www.theregister.co.uk/2020/01/28/intel_processor_data_leak/
https://www.pcworld.com/article/351...ntel-processors-with-a-fix-arriving-soon.html
AMD is not vulnerable to that L1 cache flaw though. However,Intel was given prior warning though so they could try and attempt some fixes.
