mk1_salami
mk1_salami
OP
Pump sounds normal to me, but that's not saying much! I've got the fill hole out and giving a good tilt / shake and I'm getting a few bubbles out. Will keep trying ...
The Pump is connected to the Water Pump outlet on the motherboard but although it's a PWM system I've only ever seen it at one speed (around 3000rpm).
I've just been running CPU-Z's stress test and CoreTemp reports temps of 86c. Seems very toasty to me. Is that what you'd expect?
Radiators are cool to the touch and when I cease 'testing' the CPU temperature returns to early 40's within 20 seconds.
Looks to me like the CPU block has very restricted flow. In my experience, this block comes with the 115* bracket, so it is possible you did something wrong when you fitted the AM4 bracket.
I was thinking about a different block that you have to switch out the bracket for Intel(LGA 1151, 1150 etc) with AMD's AM4. Nevermind.Could you expand on that a bit? I've managed to get nearly all the air bubbles out of the system but temps remain the same (81c CPU under stress test in CPU-Z). I rotated the CPU block 90 degrees so the fittings lined up with the EK Distribution plate. There is a small metal object inside the waterblock and the block came with a spare (different one?). What do you mean by the 115* bracket?
Here's a pic of the current setup (I re-did the GPU to CPU line and also installed the 3rd fan under the bottom rad.
Never ran CPU-Z stress mode before, here's a 3min run on my rig, stock 3900X with OC RAM, link. I open Ryzen Master at 2mins, so not correct averages, etc.
Regarding the flow, it's a funny one, because the return from Radiator 2 does not enter the reservoir at the top, but feeds into the bottom of the reservoir. Consequently, it's impossible to see any real 'flow'. I guess I could plumb in some sort of flow meter, but as it stands a video will show nothing (the fluid looks static but is clearly moving or I'd have a big problem).
Maybe I'm overthinking it and 81c in CPU-Z stress test is about right for an overclocked 3900x @ 4.1ghz.
What is your cooling setup, pump speed and fan curves etc?
What does your CPU idle at?
Ah you had the jet plate the wrong way aroundI fixed it!
Same test now 20c lower temp (60 - 61c) with fans nearly silent! Finally!
The problem was the orientation of the waterblock in relation to the blade. When i rotated it and screwed the base plate back on I did so at a 90 degree angle, so the flow through the block must have been severely impeded. I drained the loop and removed the block. Cleaned up and comparted to pics I could find in the manual and hey presto. Happy with that.
Thanks for all the help guys. Appreciated.
I fixed it!
. Yes, the jet plate opening needs to be perpendicular to fins on block. Then all the fins are getting water movement from centre to outer edges.
