- 24 Jul 2009
Just sent you an buddy request.
Nothing come through. What's your battlenet ID?
I keep clicking on the install button but nothing happens!
I'm getting rinsed by people with better guns (aka sights on AR's!) any idea where the good loot is?
I always seem to be finding Mp7's and Scar's without a sight.
Also, does anyone find the TTK is a bit too much? They need to dial that down a bit.
I have same issue, i downloaded the .exe for the standalone and it will not install. If i go via battlenet and select warzone it's forcing me to download the full game which i do own but not keen on the 183GB dl..
TTK is high but that's because people are wearing armor plates, without them people go down reasonably quick. They've supposedly made headshots more lethal than in standard multiplayer to compensate.
Every time I Alt Tab out of this game it crashes with some Direct X error message. Sometimes get it just loading the game or changing settings. Appears to be a common issue since launch but no apparent fix.
On battle.net launcher go to settings then game settings tick the additional command line arguments and put in -d3d11.
Why? Matchmaking will heavily prioritise matching you with the same input method so if you're on Xbox with a controller, you will almost always be with PS4 and PC users who are also using controller. The only time you will end up in a mix controller / KBM pool is if you have a KBM party member.Gave plunder a go...really disappointed to have to turn on cross platform to access but meh....
Yes. For Warzone you need it turned onAlready has cross play doesnt it?
I turn it off to I dont have to play people using a pad with aimbot
There were loads of ps4 & xbox players in the warzone game i jumped intoUnless you're partied with a controller user you usually won't get matched against controller users.
